-   -   Mobil 1 Synthetic for Transmission, transfer case (https://x.nissanhelp.com/forums/pathfinder/8677-mobil-1-synthetic-transmission-transfer-case.html)
racerken 08-16-2008 09:04 PM
'05 Pathfinder LE
According to the Nissan manual, the transmission and transfer case must be Nissan fluid. The Nissan Manual states that Canadian models may use Dexron II, however, nothing about a US model replacement fluid.
Q: Are the Canadian models different?
Q2: Can you substitute Mobil 1 Synthetic transmission fluid for both the transmission and transfer case?
Thanks,
Ken
mpe235 08-17-2008 05:08 AM
The transmission must use Matic J fluid only available from nissan. The transfer case takes Nissan matic D which is the same as the Dexron II so you could put the synthetic in there.
racerken 08-23-2008 12:59 PM
It turns out that my transmission uses some special fluid that is recommended for replacement at 60k miles so 25kmiles to go. I'm told that the fluid costs about $20/quart...
mpe235 08-23-2008 02:35 PM
It costs around $10.00 per quart.
