-   Latest Uploads (https://x.nissanhelp.com/forums/latest-uploads/)
-   -   NTB08-068a (https://x.nissanhelp.com/forums/latest-uploads/8607-ntb08-068a.html)
NissanTech 08-10-2008 07:46 PM
NTB08-068a
A new entry has been added to Knowledgebase
Description: -REVISED-
2004-2006 NISSAN TITAN, ARMADA; VOLUNTARY RECALL CAMPAIGN AIR CONDITIONER CONDENSER FAN
The air conditioning condenser fan motor in the subject vehicles was manufactured out of specification allowing for excessive water intrusion and inadequate drainage of moisture. If enough moisture accumulates in the motor, corrosion may occur, leading to increased temperature in the motor. Because of the motorís unique structure, this increased temperature could melt its wiring insulation and other plastic components and ultimately result in a fire. To correct the issue, Nissan will inspect, and as needed, install a thermal protector kit on the air conditioning condenser fan at no charge for parts or
labor.
To check it out, rate it or add comments, visit NTB08-068a
The comments you make there will appear in the posts below.
