-   Latest Uploads (https://x.nissanhelp.com/forums/latest-uploads/)
-   -   Ntb07-075 (https://x.nissanhelp.com/forums/latest-uploads/4633-ntb07-075-a.html)
NissanTech 11-05-2007 09:51 AM
Ntb07-075
A new entry has been added to Knowledgebase
Description:
2004-2005 NISSAN ARMADA, QUEST; VOLUNTARY SERVICE CAMPAIGN SUPPLEMENTAL RESTRAINT SYSTEM (SRS) DIAGNOSIS SENSOR UNIT
This issue only affects 2004-05 Quest and 2004-05 Armada vehicles equipped with
optional seat-mounted side air bags for which the SRS Diagnosis Sensor Unit was
replaced. For example, this part may have been replaced if the vehicle was previously
involved in an accident. Nissan has determined that the incorrect part may have been
installed in a small number of these vehicles when the sensor unit was replaced. In those
cases a sensor unit designed for vehicles without seat-mounted side air bags was used
instead of the correct one. If this happened, the optional seat-mounted side air bags may
not deploy during a crash. To remedy this potential condition, Nissan is conducting a
Voluntary Service Campaign to inspect and, if necessary, replace the SRS Diagnosis
Sensor Unit free of charge.
To check it out, rate it or add comments, visit NTB07-075
The comments you make there will appear in the posts below.
