-   Nissan Z (https://x.nissanhelp.com/forums/nissan-z/)
-   -   weird noise when Shift to 3rd gear (https://x.nissanhelp.com/forums/nissan-z/3930-weird-noise-when-shift-3rd-gear.html)
jokerak 09-04-2007 03:35 PM
i have a 350Z 03 touring, it only have 29k. here is the problem.whenever i shift to 3rd gear, it makes wierd noise, is like not a proper gear changed.i know is not the clutch.. eventhough when the car is park, engine is on. apply to 3rd gear and you will hear it. but if you reshfit to 3rd gear again. you won't hear it. but now i'm afaid change to 3rd gear.it might ruin the clutch.please help.
vpnavy 09-05-2007 03:16 AM
Until someone responds - I check around the net and found the following on your 350Z...
1. "...Original tranny was replaced after 23k miles because of grinding while shifting to 3rd gear. This tranny has only 10k miles on it, was replaced about 1 year ago and is "supposedly" the new BEEFIER trann..."
2. "...It grinds when I put it into 3rd gear..." "... I would suspect that the 3rd gear syncros are worn-out..."
There were a few other complaints - but I wanted you to know you weren't alone.
I'm sure one of the Nissan Specialists will respond shortly...
jokerak 09-05-2007 03:54 PM
thank you so much. which means i have to bring my car to the deal? also is that a recall? thanks again.
apope 09-06-2007 10:28 AM
How were you able to find out the information about this car and transmission on the net?
vpnavy 09-06-2007 10:51 AM
I didn't find any recall information pertaining to your car. You can also search the Recall and Service Bulletins for your ride on:
http://x.nissanhelp.com/forums/Knowledgebase/links/253
and
http://x.nissanhelp.com/forums/Knowledgebase/links/355
vpnavy 09-06-2007 10:52 AM
I used Google and entered (can't remember now) the year, model, transmission, 3rd gear, etc. and kept refining it until I found some information.
Dingo 03-11-2008 01:28 PM
I have the same problem. I brought my Z to Ireland, where I live now and went to the dealer here. Unfortunately they refused to help under warranty. Guys here claim I have to go to my American dealer to get it fixed under warranty. I read about this problem on many forums already. Looks like the tranny has to be replaced. No problem after replacing it with 009. For me is a cost of new tranny so I will keep it like it is now. Especially because the syncro noise is there only in high revs.
