Nissan Frontier Technical Information, Manuals, Bulletins and Recalls/Campaigns.
Technical Information with access to recall information, Full Technical Service Bulletins (TSBs) and comprehensive diagnostic and repair information
Useful Threads -- Timing Chain Tensioner Whine VQ40 repair -- Door Panel Removal Procedure DIY Projects Nissan Frontier Do-It-Yourself Projects Bulletins List: Nissan Frontier Bulletins Recalls/Campaigns List: Nissan Frontier Campaigns/Recalls Service Manuals: Nissan Frontier Service Manuals Owners Manuals: Nissan Frontier Owner's Manuals Towing Guides: Nissan Frontier Towing Guides Accessories Installation Guides Nissan Frontier OEM Accessories Installation Guides . |
I'm looking for the torque specifications for reinstalling the front brakes on my 2006 Frontier. Where can I find them?
"Brake System" section of the service manual. You can download the section free from here: http://x.nissanhelp.com/forums/Knowledgebase/links/176
I had done that and I'm guessing that one of the numbers on the "Components" page next to the bolts must be the Torque setting. Are those in Newton Meters? If so, the torque on the Torque Memeber Bolt of 185 seems pretty high.
Or am I totally off base? |
Newtons-meter (kilogram-meters, ft-lb) Here is the page BR-22: |
How do you remove the radio cluster lid on a frontier 2006 model.
Won't start
My 99 Frontier won't start I suspect a fuse or fusible link. I have power to all the lights and dash. Yet when you turn the key all you get is a click at the power socket relay on the fuse block in engine compartment.
Check all your grounds and at the starter.Also try tapping on the starter relay.
Hi All
Got a 2001 -Diesel Nissan Frontier with King Cab with YD25 Ti engine and 5 Fw Manual Trans. Situation has always been a very hard clutch pedal - replaced clutch plate/pressure plate pilot bushing twice within the last two years. Old parts seem fine. It comes out of the shop working fine and then after about two months or so -gets back hard. Can some one please help ? Please advise if there is a link for the service manual for this diesel model. Thanks in advance, Lawmanruiz |
donde esta el "konck sensor ' en un 2000 nissan frontier 6 v
my nissan frontier won't grab reverse
Anyone know how to remove the vent control valve on a 2005 Frontier? I've got the hose & electrical plug disconnected but can't get thevalve out, even after turning it almost 180 degrees.
