-   -   No fuel from injectors (https://x.nissanhelp.com/forums/altima/31987-no-fuel-injectors.html)
ColeWelch 06-08-2020 06:12 PM
On my 2006 Altima w/ 2.5L cranks but won't start. Was driving down road one day and it died. We towed it home and it hasn't started since. Check engine light never came on. It shows 0 codes. Had a guy run his snap on diagnostic scanner on it and he couldn't figure out the issue either. Will fire on starting fluid but dies out. Things I have done or tried so far...
Replaced fuel pump
Replaced crank position sensor
Replaced cam position sensor
Checked compression and timing
Checked every fuse in car
Swapped out all relays.
Fuel pump is working and pressurizing the lines. Also not sure about my immobilizer but light stops flashing when trying to start car and when key is in on position. Anyone have an answer to my problem.
