3-pod gauge cluster ribbon connector
Greeting all,
New here and new to Nissan. I am resurrecting a 2005 350Z Roadster that has been neglected. While removing the center dash bezel containing the temp controls, radio, navigation cubby and 3-pod gauge cluster the "ribbon connector" for the 3-pod gauges broke in two. I have found this description of the part: 10 pin, 1.25mm pitch, type A, 210mm length. It is a flat, white 10 pin ribbon connector that I provides input to the 3 gauges in the top middle of the dash. I appears that I may be able to install a new ribbon into the existing connectors. If you cannot help direct me, it looks like this ribbon could be sourced from a computer supply store. Hoping to find a true Nissan part. Hope you can assist. Thanks, Pilgrim Trucker |
Called a Nissan dealer today and talked to the parts guy; this ribbon is part of a circuit board assembly, part #24898-CD010. Not sure if it's still available, I didn't want to trouble him further after he quoted me $268.00 for the assembly.
I understand, but I only need a $3.00 ribbon connector. Checking with a computer parts place next. Still holding out hope someone here will offer up some help. Thanks, Pilgrim Trucker |
