-   -   01 xterra turn signal problem (https://x.nissanhelp.com/forums/xterra/31910-01-xterra-turn-signal-problem.html)
huffthemgcdrgn 03-19-2020 05:09 AM
i've been fixing up a 01 XTerra after a minor front end collision. i have checked/replaced all bulbs/assemblies and even the back connector for the frt left assy. all signals work with the exception of the frt left. parking lamp works. when i put my meter on the connector i get a constant 1.42 vdc on the flasher wire.this remains constant with the signal on or off, eng on or off. pulled the fuse, flasher relay, and disconnected the multi function switch, voltage still 1.42. i suspected possible wire damage shorting to another system inside the harness/bundle but have found no damage. also, now the rear wiper/washer pump comes on! maybe the mysterious Super Multiple Junction?
