-   -   radiator fans not running during normal operation (https://x.nissanhelp.com/forums/sentra/31889-radiator-fans-not-running-during-normal-operation.html)
Bigdawg 02-23-2020 08:04 AM
I have a 2010 SE R. I recently had the thermostat and coolant temperature sending unit replaced since the car has 170000 miles and those items never failed to date. I did a radiator cleaning and flush and during the process I let the car run for two hours before draining. What I noticed was the radiator fans never came on during the two hours the car was running. I checked the coolant temperature and the level was at the halfway mark during the process and didn't move at all. If I turn on the AC the fans click on, but under normal operation the fans don't run. Is that normal or is there an issue I should be concerned with?
