-   -   05 Frontier weird problem (https://x.nissanhelp.com/forums/frontier/31777-05-frontier-weird-problem.html)
kzap 11-17-2019 06:57 AM
Hi All,
I have a really weird problem and I’ve been searching the web but couldn’t find the cause of it. The problem is whenever I turn off the engine, I have to wait at least 15 minutes for the engine to fire up again regardless of the engine temperature. During that fifteen minutes everything is normal such as cranking, lights, radio etc…. I replaced camshaft position sensors and also crankshaft position sensor. I even replaced the IPDM and the problem still persists.
Thanks
JRJoe 11-17-2019 09:39 AM
Originally Posted by kzap (Post 108167)
Hi All,
Thanks
Kzap,
Stop throwing part's at it hopeing that they'll fix it. Take it to Nissan and tell the service manager the symptom's, let them diagnose what the problem is and my advice is to let them fix it as well. Although Nissan's Labor charge's are high,, it may very well in the end be the cheapest way to go.
Not knowing what you're doing and playing around with the electronic's on these Truck's can get you in a pretty deep Rabbit hole before you know it.
Regards,
kzap 03-01-2020 08:57 AM
Just an update for those who might run into this problem in the future. The culprit are the aftermarket camshaft sensors. I replaced with the OEM ones and the problem is fixed.
JRJoe 03-02-2020 12:40 AM
KZap,
Thanks for letting us know what the problem was and I'm glad that you got it going again.
Which Engine and Transmission ie AT or MT, do you have?
Regards,
kzap 03-07-2020 07:14 AM
2005 Frontier Nismo 6 Cyl 4.0 L, AT, 4WD.
