-   -   need advice on how to remove VTC on 2010 sentra (https://x.nissanhelp.com/forums/sentra/31742-need-advice-how-remove-vtc-2010-sentra.html)
krajef 10-19-2019 02:09 PM
Hi
Looking for some advise on how to remove the vtc on a 2010 sentra 2.0.
any links on a video would be helpful. Mine is under motor mount and in a tight space. I hope I can get to it if I pull the plastic fender shroud.
Thanks in advance
Jeff
dean42mvg 10-21-2019 10:55 AM
does this help ?
YouTube
krajef 10-21-2019 04:45 PM
Hi Dean
This doesn't look like the same engine. I have the 2.0. looks like my vvt is at the front of the engine. I pulled the inside splash fender off and there is a circular hole and I am able to see the vvt. I pulled the *mm bolt and the dam thing was seized. I spun the ear and used pin nose pliers to pull and only half of the shit ass thing came out. Tomorrow I need to figure out how to remove the rest. There is no hole so I can't so the screw and wheel puller trick. I'm going to try a stronger pin nose pliers to grasp the 1/4 in lip maybe this will work. Worse case a small hole with a small screw and some shavings in the engine. This just has me really ticked. I hate the fact that the intake plenum is over the engine where you cannot disconnect the coil packs with the engine running. Oh well I will post how I make out tomorrow and thanks for the reply.
Regards
jeff
krajef 10-22-2019 05:46 PM
Got the VVT solenoid out after is broke
2 Attachment(s)
Got the VVT out after is broke in two when I was pulling on it. Pictures attached. I found a bolt that I was able to thread into the short opening and pulled some with the end of a hammer.
