-   -   Trouble with my Sentra (https://x.nissanhelp.com/forums/sentra/31706-trouble-my-sentra.html)
JamesO84 09-25-2019 07:01 PM
Ok I bought the car from a woman said it needed a new radiator cause it had the wrong one on it so I replaced it with a brand new one and now it still bubbles when you cut the car off and temp hand goes up but when I cut it off it has trouble want im ng to start like its flooded and if I pat the gas when cranking it will finally crank. Theres no water in my oil or anything but it's a 1999 Sentra
smj999smj 09-29-2019 10:34 PM
There may not be water in your oil, but is coolant getting into one or more of your combustion chambers? You have some symptoms of a bad head gasket. I compression and cylinder leakdown test would help confirm if it is or isn't a problem.
