-   -   2002 Xterra cranks wont start (https://x.nissanhelp.com/forums/xterra/31543-2002-xterra-cranks-wont-start.html)
AngieBaby69 06-26-2019 05:04 PM
My 2002 Xterra 2.4l manual transmission won't start. I am trying to determine if it is the distributor or the ECM/ECU before I buy either part. Is there a way to do this? I have already replaced the plugs, dist cap, and rotor button due to a misfire and no power under a load. It ran for awhile, then it broke down and would not start back. I got it towed and it had no spark. I replaced the ignition coil pack and it started and ran rough but now its back to no start. I do not have a spark from any cylinder so I am trying to determine which way to go next without buying both parts since I have limited funds.
Thanks!
smj999smj 06-26-2019 08:28 PM
NICO Club's site will give you access to a free, online, factory service manual for your vehicle. You'll want to click on the "ec.pdf" which is the Engine Control section of the FSM. On page EC-128, there is a "Symptom Matrix" you can use. It will help you get to the right section you need, which will give you step-by-step diagnostics to help you pinpoint your problem.
Nissan Factory Service Manuals
