P/S pump front seal replacement
My pump is leaking in the front, behind the pulley. went to Nissan shop and bought the front repair kit. When remove the pulley there's a bearing instead of a seal. The kit is a seal and a snap ring. This is the wrong kit or the seal is behind the bearing. I don't want to open it, the rear kit is $80.00 plus the front better buy a new pump.
Any advice Thanks |
Well, the place where you are buying your seal kit for is overcharging you. Technically, you need both kits, because it's best to take the back cover of the pump off and remove the shaft so it doesn't get scratched while trying to take the seal out. The following are the Nissan kit #'s and their MSRP price, although you can get them cheaper online:
Kit "A": 49591-03U28 $48.55 Kit "B": 49119-30R27 $22.93 (Note: NissanPartsDeal.com has the two for a total of $52.45+shipping) Now, that's cheap considering a new pump is in the $400+ range from Nissan! Now, that all said, you can go to Rockauto.com where they have P/S Pump re-seal kits that contain both "A" and "B" kits and cost under $13 not including shipping! That would be what I would use. The Edelmann # 8799 seal kit is $7.35+shipping and the Gates # 348377 kit is $11.42+shipping. More Information for GATES 348377 |
