-   -   07 Altima 2.5 please help .. car turns to the “ON” position but won’t spin over (https://x.nissanhelp.com/forums/altima/31495-07-altima-2-5-please-help-car-turns-position-but-won-t-spin-over.html)
Troc30 05-10-2019 02:56 PM
07 Altima 2.5 please help .. car turns to the ON position but wont spin over
The car was running but had a lil sputter/ stutter as in misfire . Checked the coil pack on cylinder 1 . The plug was faulty and broken so I replaced the plug and the car crunked up but it was still misfiring , while the car was running , I took one of the wires from the plug a loose and the car cuts off .. so I put the wire back together and tried to start it and wouldnt say anything .. I replaced the crank sensor , I replaced the brake light switch , the cruise control switch and also took the positive battery cable off for 30 mins trying to reset the computer but I still have the same issue . NOT CRANKING UP . So if anyone had this same issue please help me out ..thanks in advance
Troc30 05-11-2019 12:14 PM
Update ... I checked my fuse box under the hood and it blowed the fuse to the ECM replaced it with a 15 fuse and she started right up and I had to change that one coil pack out too it was burned also
Desmorhnd 07-25-2019 12:17 AM
Please I need help on my nissa altima 2007, Firstly I drove around on a rainy day and I came back and parked, later that evening the ac fans started to work by itself(the car was parked and car not on) I quickly pressed the unlock button on the key and it stopped, I turned it on for a while so the battery could charge and all, later again that night the headlights turned on by itself I quickly went to start it then I saw a wheel sign on the dash, it later went off and I tried starting it and up till now it still hasn't worked
