-   Titan (https://x.nissanhelp.com/forums/titan/)
-   -   Speed sensor part number (https://x.nissanhelp.com/forums/titan/31492-speed-sensor-part-number.html)
LILJHC76 05-06-2019 05:46 PM
I need the vehicle speed sensor part number for my truck speedo not working and i'm getting the p0500 code all i keep getting is the revolution sensor when i look it up on google i'm a in the right direction
smj999smj 05-14-2019 05:31 PM
The system uses the ABS wheel speed sensors for the speed input. So, you need to check for stored "C-codes" and/or use a scan tool to monitor the ABS wheel speed sensor outputs. You might want to do a visual inspection of the wheel speed sensor harnesses, first, to see if there is any damage or chafing through the insulation. Other possible causes for a P0500 code include an open or short (harness and connectors) in the wheel speed or CAN communications circuits, a bad cluster or a bad ABS actuator/control unit assembly.
