-   -   2004 Nissan Sentra 1.8S- Engine Revving Up and Down (https://x.nissanhelp.com/forums/sentra/31482-2004-nissan-sentra-1-8s-engine-revving-up-down.html)
RaynesHavok 04-24-2019 02:04 PM
I have a 2004 Nissan Sentra 1.8s, Automatic. ODO 162592. At First I could only get it to start with using Car Starting Fluid and eventually would stall out. So I got a new fuel pump and put that in. It ran fine at first for a few days, then the fuel pump would whine really loud and the engine started Revving up and down between 1500 and 2000 RPM. I immediately thought the fuel pump was faulty due to the the loud high pitch noise. After returning and getting another fuel pump and installing it, the engine is still revving between 1500 and 2000 RPM but the high pitch noise I would hear from the fuel pump has stopped. I checked the codes and got a P1121. Which told me it was the Throttle Body. So I got a whole new Throttle Body Assembly and installed it. I did the pre checks for the Relearn and everything passed. I started the car which was idling fine at first but after a couple of minutes. It began Revving between 1500 and 2000 RPM again. Thinking I still needed to complete the Relearn and have done it 10 times following and completing each step and messed up like 3 times in between but would stop for 5 minutes and retry and complete each step. And everytime the Engine is still revving between 1500 and 2000 RPM. I have checked all the vacuum lines and they seem fine and connected correctly. I sprayed the MAF sensor with some fast drying Electronic Cleaner and Air Filter is brand new. Only thing I can think of is the MAF Sensor is still dirty or need a new one but not sure. No new code yet. Gonna let the car sit and try again in the morning since I got frustrated.Any Advice would be much appreciated.
