-   -   I cant find the bank 1 crankshaft sensor on Nissan 2001 Xterra (https://x.nissanhelp.com/forums/xterra/31477-i-cant-find-bank-1-crankshaft-sensor-nissan-2001-xterra.html)
vanioli2001 04-20-2019 05:16 PM
Ive been looking for a long time online and I cant find any diagrams that show the 2001 Model. I could only find older versions. If someone could show me where the Bank 1 crankshaft sensor is on a 2001 Xterra that would be great. Thank you
smj999smj 04-29-2019 10:10 PM
If it's a VG33E engine, the crankshaft position sensor is located on the top of the transmission bellhousing, a little towards the driver's side. It'll have a small, metal shield over it (if it wasn't removed and discarded by someone else in the past) and is held in with a 10MM head bolt. You can see it if you remove the driver's side wheel and look through the gap between the body sheet metal and the frame. To replace it, you need to access it from the bottom (it is much easier with the vehicle on a lift), reaching from the driver's side of the transmission and, if it's 4WD, past the front driveshaft (you'll have more room if you remove the shaft), up to the sensor at the top of the bellhousing.
Search Engine Optimisation provided by DragonByte SEO v2.0.42 (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
