-   Quest (https://x.nissanhelp.com/forums/quest/)
-   -   Mass Air Flow Sensor (https://x.nissanhelp.com/forums/quest/31379-mass-air-flow-sensor.html)
surfcity 02-27-2019 04:06 PM
Hello, I have 2012 Quest that has almost 120K. A warning light came on the other day. The code shows it is Mass Air Flow Sensor. So, I decided to clean the sensor first. If that doesn't help, I would replace it. Anyway, I looked the location of the sensor under the hood. It's located way back, almost under the dashboard and its facing inside. What a poor design. There is no way I can reach it unless I remove the other parts and disassemble the cover that the air filter is in. Has anyone done this without taking apart? Are there any easier way to do this? Thanks for your help. Best,
smj999smj 03-02-2019 01:18 AM
Found this link that should help:
Nissan Mass Air Flow MAF Sensor Replacement
