-   -   2007 2.5S hesitation problem (https://x.nissanhelp.com/forums/altima/31035-2007-2-5s-hesitation-problem.html)
HULK_SMASH-65 08-25-2018 09:50 AM
I have a 2007 Altima 2.5S with 181,000 miles on it. I recently changed the fuel pump as I was having a hesitation problem at low rpm only. I also changed the CVT fluid while I was at it. In addition to the fuel pump, I added two cans of BG44K fuel cleaner ( one can per tank of fuel) and I still have the hesitation problem. I have also replaced the coils/plugs and valve cover prior to this problem and did not experience this problem until sometime after. Any help is appreciated
HULK_SMASH-65 11-12-2018 12:33 AM
Well, I found the issue... The wires going to#4 cylinder had become bare. The insulation was brittle and broke off causing it to short out the coil. Fixed that and the problem went away.
Search Engine Optimisation provided by DragonByte SEO v2.0.42 (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
