-   Armada (https://x.nissanhelp.com/forums/armada/)
-   -   P0734 (https://x.nissanhelp.com/forums/armada/31021-p0734.html)
Mike S. 08-20-2018 02:29 PM
P0734
Driving home i had smoke in my rearview mirror. The RPM’s would go real high and the vehicle would not go when given gas. I coasted to a locationion off the highway. The undercarriage was dripping wet. I discovered a line for the radiator fluid was split and spewing fluid. I cut the bad area off and reconnected the hose and added more fluid. There were no idiot lights indicating anything else. When i drove off, the RPM’s would go really high again but i was able to get home. After a while, the engine light came on and is showing P0734 “gear 4 ratio incorrect” need advise on what i need to do here, or should i just take it in to the dealer? Prior to this happening, i did not have any issues. I guess i should add that i have a 2012 Armada.
smj999smj 08-25-2018 02:47 PM
I would double-check the ATF level and if it's okay, take it to a reputable transmission shop.
