-   Altima Hybrid (https://x.nissanhelp.com/forums/altima-hybrid/)
-   -   Replace Auto Shift Cable problem (https://x.nissanhelp.com/forums/altima-hybrid/30688-replace-auto-shift-cable-problem.html)
KGart0n 05-22-2018 01:59 PM
2 Attachment(s)
The Shift Cable on my 2009 Altima Hybrid Broke right at the Transmission.
Got the console out no problem and I was able to remove the HV ECU following HBC-644 in the service manual. Pull out the HV ECU to RH side, If necessary, remove the screws and HV ECU brackets from the HV ECU.
The 4 screws and pulling out the HV ECU to the right was pretty easy, but in order to get to the 2 screws I have to remove the HV ECU mounting bracket over the Shift cable where it goes through the floor of the car so I can get to the cover screws. The bracket had 2 screws under the HV ECU that I got out, but it looks like there are 2 screws at the top into the firewall. I can get my hand in enough to feel the heads but there is not enough room to remove them.
The service manuals ?If necessary, remove the screws and HV ECU brackets from the
HV ECU" is not very helpful. I've attached a couple of pictures. Anyone have any thought so I don't have to pull dash out?
Howard Bell 05-23-2018 02:54 PM
Are you sure the cable doesn't just go straight through the firewall right there where you last see it? My reasoning is that it must be doable, the service manual will definitely tell you dash comes out if that is really needed.
