Airbag Light Flashing - B1049, B1054
I just bought 2006 Quest and airbag light is flashing. After researching the Internet and watching videos on Youtube, I tried to reset the light and it didn't work (Tried about 10 times now).
After scanning, I got 2 codes; B1049 and B1054. After learning possible causes for these codes, I am trying to do some things that I can do before I move on to the expensive fix. I want to look for poor electrical connections and open airbag harness but I don't know where the connections are or where to look for. I looked under the seat and I did not find any. According to previous owner, the van was not involved in any accident/crash. He had Sirex radio (sp???) installed and connecting 'jacks' are on dashboard. The owner could't tell me when the light started blinking. The van has about 120K miles on it. FYI, the horn, cruise control, factory radio and cigarette lighter work. Does anyone know how to fix this issue? Thanks in advance for your input. |
Both of those codes are for the driver's air bag module (open circuit). This is the actual air bag part that is mounted to the steering wheel. The open could be inside the air bag, in the spiral cable (clockspring), the yellow air bag harness or the air bag control unit, itself. Nissan SRS diagnostics are very basic; there's no resistance or continuity checks in their procedures, mostly for liability and safety reasons. They are generally visual inspections followed by replacing parts, one at a time, until the problem is fixed. Yes, that can get very expensive! However, it is what it is!
The 2006 Quest factory service manual is really what you need to tackle this problem, specifically, the SRS chapter. Fortunately, that chapter is available for free download in the "knowledge base" at this site: http://x.nissanhelp.com/forums/Knowledgebase/links/162/ Page "SRS-23" has the code and diagnostic code and repair chart that you will want to look at. Remember: working on airbag and restraint systems can be dangerous if you are not careful or know what you are doing! Read the precautions at the beginning of the SRS chapter before working on these systems. Many times, especially when dealing with connectors or removing/installing parts, the battery cable will need to be disconnected for at least 10 minutes before it is safe to work on the vehicle. If you need to remove the air bag module bolts, you will need a tamper-proof torx socket, size "T50X." |
Hello. did you find your trouble, I have the same code B1049 and B1054 on my Sentra 2009, what did you do to repair ?
Thank Luc |
Sorry for the delayed response.
I had to replace Clock Spring on the steering wheel underneath the airbag. |
Thank 2001I30MAX
I just to change clock spring too, now it is good, no code I bought one use with controls flasher and high lamp at junkyard for $10.00 Luc |
I have codes B1049 & B1054 on my 2010 Nissan Frontier but horn and cruise control works
Allo Hbag179
It seems to be the Clock Spring on the steering wheel underneath the airbag even if your horn and cruise control works. video YouTube |
Luc,
thank you for the quick reply. I will give that a shot. |
Hello, After changing the clock spring in my 2006 Nissan Quest, the air bag light will not go out. Everything on the steering wheel works: horn speed control, radio, etc. I tried all the procedures on YouTube, but nothing works. Can some one tell me the size resistors to use to jump the air bag, passenger mat sensor, seat belt latches. Then, I can eliminate each component, until I find the bad one. Also, I am in the process of checking out the wiring. I am 81 years old and live on a fixed income. Can not afford to take to shop or buy expensive parts. And, can not afford to buy a OBD11 scanner. I also need a list of the flash codes from the SRM light. I bought a chepo ODB 11 reader, but it was a piece of junk and did not work. Then, I tried to connect an ODB11 to my laptop. But, that did not work either. I am a licensed Master Electrician, ( or use to be0)I have been working on this for weeks with no results. My inspection is due in three months. Any and all help will be greatly appreciated. My email address is [[email protected]] Thanks. Mike Ange, Virginia Beach, Virginia
Airbag Warning Light
When I reconnected the new clock spring, a small plastic tab on the male connector was bent, and prevented good electrical contact between the air bag and clock spring. After reinserting the connector properly, the warning light went out. No more flash codes indicating a malfunction in the system.
Needless to say, had I been more gentle in making the connection, there would have been no problem. And, saved me days of work. However, the knowledge gained about the SRS system on my 2006 Nissan Quest was well worth it. I did not know what a clock spring was two months ago. And, surely did not understand the workings and components in the SRS system. I had disconnected every part, and reassembled them, just to find our that the problem lay in a small plastic tab almost unnoticeable . But, the effort was worth the time and money spent, because of knowledge gained. I love my old beat up Nissan Quest, and really wanted to keep it. But, if I can not keep up the repairs, it has to go. lol Thanks you, Mike in Virginia Beach |
