-   Audio, Video & Electronics (https://x.nissanhelp.com/forums/audio-video-electronics/)
-   -   Armada slip light and 4WD light flashing, no throttle response (https://x.nissanhelp.com/forums/audio-video-electronics/29443-armada-slip-light-4wd-light-flashing-no-throttle-response.html)
Reedhenrypi 02-26-2017 08:48 AM
I have a 2007 Armada se 49k 4x4. Driving on the highway +65mph the Slip light and 4wd light flash on dash and there is no acceleration In both 2wd and auto 4wd. Any suggestions?
Thank you,
Reed
mpe235 02-27-2017 01:19 AM
Thank you,
Reed
Make sure the wheel bearings are not loose and the brake fluid is full. If it's not that you will need a scan tool to check the codes.
Reedhenrypi 02-27-2017 05:17 AM
Bearing, fluid and ABS sensors all good. I took it to belle tire and they didn't get any codes. Not sure what scanner they used.
