2017 Rogue Lane Departure Warning
There is a warning chime and the blinking LDW light, but should there be anything additional? Is Lane Departure Prevention, which is supposed to "gently guide you back", actually a feature, or something that never made it to final production?
That's all there is, although I think it's enough, I like the soft chime as it's not too startling.
I just purchased a fully loaded Rogue 2017. I cannot find the menu to activate the Lane departure prevention system. It should be located just below the Lane Departure Warning button in the menu as per the owners manual. It is as if it is not even installed????
Anybody have an answer. I paid for this system so it should be there. |
Go to settings/driver assistance/driving aids/lane/warning.
Hope this helps |
I did that and there should be a second box labelled Lane Departure Prevention as per the manual it is not there.
What page in the manual are you looking at? |
http://www.nissan-global.com/EN/TECHNOLOGY/OVERVIEW/ldp.html |
http://nissannews.com/en-US/nissan/usa/channels/ca-canada-infiniti-technology/videos/lane-departure-prevention-ldp
Okay so you have to press the button on the dash each time the vehicle is started in order to activate the lane departure. I got it to work and it does brake and bring you back into the lane very slightly. The button is the little car with the circles around it.
Laane departure prevention
I have a 2017.7 Rogue SL with premium package. When I start up and press the lane departure prevention button, the light come on, but I can not sense any braking or steering wheel tug when I cross solid lines.. Is there any other way of verifying that it is functioning?
You will barely notice any braking at all but it is there. The button with the circle must be on everytime the vehicle is started. I find this a useless option that probably just causes undo wear on your brake pads.
I didn't notice the braking or a tug on the wheel.
Try very slightly crossing the centre line, 3 of the four brakes should come on and very slightly it may return you to the lane
"Phantom" Lane Departure Prevention feature.
The Lane Departure Prevention is a worthless feature "if" it is even really there.
The manual says to check the Assist box under the user settings under Lane. There is no Assist check box. When turned on it is suppose to brake and assist you back to the lane. I have tried it with the cruise control on and off at different speeds with solid white lines on both sides and all I get is the warning, NO assist. I would like Nissan to explain this to all the owners that paid for this feature. |
