Headlight change 1995 pathfinder
I guess I am just not seeing it, but i cannot see whare the bolts/screws that hold the headlight on are.
I am not speaking of a lamp change. My headlight has a small hole in it in the bottom that lets water in and blows the lamps when the water hits it, so i want to replace the whole headlight. Or I can just put a goldfish in there and have a conversation piece on the front of my truck. |
Re: Headlight change 1995 pathfinder
Seriously, there has to be some screws or some clips holding it in place. I'm not that familiar with that model but if you look a little harder, you should find something. Maybe NissanTech will point you in a more specific direction. Worst case scenario, find a mechanics book at your local Pep Boys or Autozone and it will tell you what you need to know. |
dude, look again. two screws hold the turn indicator on. take those off and remove the corner lamp. then you'll see how the head light comes off. 8)
