Doors constantly unlocking
So our 2008 Altima SE Coupe with 63k has a ghost in the lock system and it's driving everyone that gets in it absolutely nuts. :rolleyes:
Apparently even after it's locked either manually or with the fob and alarm set the thing clicks randomly during the night as well with the interior lights coming on etc. I see similar posts in other forums with MOISTURE being touted as the source of the issue, however if that proves to be the case here I am NOT going to be pleased. I mean this problem has started in the past month and is getting worse with the weather having brought New England to relative drought conditions this year. ANYWAY! I intend to: 1. Change Key Fob batt and check programming. 2. Open the drivers door panel and actively dry out control components. I will return and advise as to my results but if anyone has any gem's of wisdom on this kindly reply here...THANX:drinks_cheers: |
