Radio Problem please help
Ok so I just bought a pioneer radio from walmart wired it up and everything but my radio won't work I have a 04 nissan altima .. Already checked fuses and everything
Did you cut and splice the wiring,or use a harness adapter? If you used an adapter make sure it is the proper one for your car and radio. If you cut and spliced, recheck the wiring diagram. Verify that all connections are "good" and insulated. Don't use wire nuts, use crimp connectors or solder all splices.
