-   -   05 pathfinder driver & passenger side mirror assembly replacement (https://x.nissanhelp.com/forums/pathfinder/28190-05-pathfinder-driver-passenger-side-mirror-assembly-replacement.html)
JayBo 03-15-2016 06:13 PM
I recently bought new electric mirrors and need help with the install. How do I get the old mirrors off? Thanks in advance.
NissanTech 03-15-2016 07:17 PM
2 Attachment(s)
Here are the instructions from the service manual, I hope it helps:
REMOVAL
Be careful not to damage the mirror bodies.
1. Remove the adhesive front door sash cover.
2. Remove the front door finisher.
Attachment 4302
a. Remove power window switch assembly.
----Disconnect harness connectors.
b. Remove pull handle escutcheon.
c. Remove pull handle cover and remove screw.
d. Lift armrest upward to release clips and remove armrest.
----Remove screws behind armrest.
e. Remove memory seat switch (if equipped).
----Disconnect harness connector.
3. Position the front door seal aside.
Attachment 4303
4. Disconnect the door mirror harness connector.
5. Remove the nuts and the door mirror assembly.
