Help locate Altima 2.5S Oxygen Bank1 Sensor 2
Long story short, Nissan Altima 2009 sedan 2.5SL, get check engine light on, check the code indicate to change Oxygen Sensor on Bank 1 Sensor 2. down stream sensor.
Opened the hood, only see 1 sensor there, not sure if that is correct 1, can any one help? please see following pic. http://i67.tinypic.com/2w6z0j8.jpg http://i63.tinypic.com/14np647.jpg http://i64.tinypic.com/353aa6u.jpg Thank you very much. Dave |
Remove the heat shield just right of the oil dip stick with a 10 mm socket. The CAT should come to view. The top is sensor 1 and bottom is sensor 2. You will need a 7/8" oxygen sensor socket. Use NGK or Bosch oxygen sensor.
I would say use NTK (NGK's brand of Oxygen sensor), genuine Nissan or Denso. I've had some issues with Bosch sensors in Toyotas and Nissans. Soak down the shield bolts as the tend to rust and break when you try to remove them.
Thank you, I will check.
Thanks for the info. I will avoid Bosch then :)
were you able to fix the problem?
