2002 Nissan Pathfinder LE
2 weeks after passing inspection, the airbag light started flashing and would not stop. The Abs and 4wd steady yellow light came on. When turning the ignition on again those steady yellow lights went off. My airbag inflator was recalled and replaced in September 2014. No accidents since and airbags never inflated. Please help.
Try disconnecting the car battery for about 30 min to clear the codes. If the light comes back, you need to have the dealer or a shop check for codes. Without the codes you will be just guessing what the problem is.
