-   Rogue (https://x.nissanhelp.com/forums/rogue/)
-   -   Belt Tension (https://x.nissanhelp.com/forums/rogue/27682-belt-tension.html)
AllanD 09-23-2015 02:08 PM
Belt Tension
Want to first start off saying Hello, new to the forum.
I have a question is there a way to add tension to the serpentine belt? Mine snapped and I replaced it, which was a task for me since I don't know what I am doing. But now when I turn on the heater/AC it squeals really bad. So I thinking the belt needs to be tighter.
Any help would be great.
mpe235 09-23-2015 03:10 PM
check the belt routing. It will fit two ways, one will be loose and the other will be tight. You probably have it on wrong.
2008 NISSAN ROGUE BELT ROUTING DIAGRAM
AllanD 09-23-2015 03:41 PM
I looked and relooked again and the belt is on the wrong way. I will be redoing this tomorrow. Thank you for all the help.
