-   cube (https://x.nissanhelp.com/forums/cube/)
-   -   Junk Yard CVT - plug and play? (https://x.nissanhelp.com/forums/cube/26512-junk-yard-cvt-plug-play.html)
Tim Lambert 12-04-2013 07:34 AM
Can a Nissan CVT transmission be replaced using a salvage yard trans?
Do the trans parameters have to be reset in the ECM or Trans control?
In other words could a person just plug and play a CVT into a 2010 Cube?
G47 12-07-2013 09:38 AM
why do you need a CVT transmission? just so you know Nissan has extra extended warranty on CVT transmissions
"10 years/120,000 miles, whichever comes first."
Nissan CVT Warranty Extension
smj999smj 12-08-2013 09:10 AM
And, in addition to the above point, "no," it's not plug and play. You'll need a Consult III scantool to perform a TCM initialization procedure.
mpe235 12-10-2013 02:21 AM
It will function but the initialization procedure should be done. Any scan tool that can access transmission codes can be used to do this.
Tim Lambert 12-12-2013 01:15 PM
Thanks, mpe235 and smj999smj. That's exactly the type of info I needed.
I suspected a salvage CVT trans might need to be "initialized". On the equipment I am familiar with I would have called it "calibrated" - Yale or "learned" - Raymond. I might have to get a dealer to perform this so I need to know what to ask for.
@ G47, the local Nissan Dealer will not perform warranty work on my Cube because it has a "branded" title. My paper copy of title is not "branded" but according to Nissan Consumer Affairs (I took your advise in a previous post you answered) my Cube is "branded" due to "mileage discrepancy" and Nissan will not do warranty work on my Cube unless I can get Ky. DMV to remove the "brand" from their records. I may try and pursue amending the title but I honestly don't think it can be done.
In the mean time, a friend that works at a local auto salvage has a low mileage 2010 Cube that had a good CVT in it for $800. I plan to get this CVT and swap it into my Cube ASAP. I might even take a peek inside my old CVT to see what's worn! I suspect the belt and or sheaves?
