flashing tire sensor light
my 2008 rogue tire sensor light is flashing...i checked my pressure and put air in but the flashing is still on. does anyone know why?
You would need to retrieve the trouble code to help determine the problem. This can not be read by the typical OBD II code reader used by many parts stores, but a scantool capable of accessing the codes of the TPMS system. The TPMS sensors usually have a life of around 6 to 8 years, so it's very possible you have a TPMS sensor with a weak or dead battery; the battery is not serviceable, requiring replacement of the sensor.
ok, thank you very much!
TPMS flashing
Usually when the light is flashing it means that the car cannot read one or more of the sensors. The battery life on the sensors is between 5-8 years. you can find low cost replacements at Titan TPMS Tire Pressure Sensors
Dorman direct-fit sensors are about $40 each from Rockauto and have a lifetime warranty.
