2007 Nissan frontier upper intake or Plenum Gasket change
It there anything I need to watch for or is everything straight forward Going to change spark plugs and PVC also while changing Plenum |
I see all these issues snapping blots hope these specs are right for changing upper intake -plenum
INSTALLATION Installation is in the reverse order of removal. Note the following: Intake Manifold Collector If stud bolts were removed from intake manifold, install them and tighten to the specified torque. Tighten nuts and bolts in numerical order as shown. Tighten bolts in numerical order as shown. Intake manifold collector bolts and nuts : 11.0 N·m (1.1 kg-m, 8 ft-lb) Stud bolts : 6.9 N·m (7.0kg-m, 61 in-lb) <<<<<< Is this to much?? |
Thanks i make a note of that this is the reason i am changing Fault Code Definition
OBD II P0171 Fuel System Too Lean (Bank 1) OBD II P0174 Fuel System Too Lean (Bank 2) One thing i dont do is check to see if my PCM software needs to be updated really dont know how so I jumped to the second step Common Problems That Trigger the P0171 and P0174 Code PCM software needs to be updated Vacuum leaks (Intake Manifold Gaskets, vacuum hoses, PCV hoses, etc.) Mass Airflow Sensor (MAF) Plugged Fuel Filter or weak Fuel Pump Plugged or dirty Fuel Injectors |
2007 Nissan frontier upper intake or Plenum Gasket change Took about 2 hours on this job all looks good so far have to wait and drive it and let the computer recycling system.
Changed Plenum Gaskets ,pcv valve Spark plugs, changed throttle body gasket Only small issue you may want to do is make sure you loose the wiring harness push back out your way ,,, and also take off the 3 fuel inject wires from the side your working on.. |
File download allowance for register users is 2 files per day. I have not viewed one ! Why can I not view 1 without subscribing?
corko |
