rear door handle
The passenger side rear door on my 2001 Pathfinder will not open the door. It would not open from the inside either, but I took off the interior panel and got it to open. Would like to get it to open from the exterior but can not determine how to accomplish this. There is little room to get a hand in there. The door handle just flaps like it is not connected to anything. Any ideas on how I can re-connect it?
Thanks Ekmols |
Two possible problems. Others have had the plastic lever break. I had the outer of the cable break at the handle end. Remove the two plastic plugs on inside of door and then two 10mm nuts to remove the handle. If it's the cable, I repaired mine with a wide cable tie - sorry no photos but you should be able to work out how to secure it. Don't know how long that will last.
