Is this my Xtrail Heater Fan Resistor?
Hi everyone,
I have been reading every forum entry I can find regarding Xtrail heater fan resistor problems. I have a classic resistor failure scenario - fan only works on setting 4 - and I wish to replace it. Before I attempt to find a replacement part (I am in NZ) I thought I would make sure I could locate the offending item in the car and remove/replace it. Firstly, I am not a car-tech person, but the instructions I have read seem simple enough. So, I removed the cover beneath the glovebox and looked up. After a lot of searching (and back-breaking contortions) I found what I think might be the resistor. It is at the back of what I assume is the blower cover (which is white?) and it is set into another piece of bodywork. It has a large plug into it and is secured by two fairly fat screws. I took a photo and have uploaded it in the hope that someone can confirm that I have located the right part! Can anybody help with this? Brian |
Hi!
Yes that is the module that controls the fan speeds. I had the same problem with only speed 4 (hi) working. Remove this item & replace & all will be good! I found one at a local jap parts place in Sydney for $75. |
Hi chamz5,
thanks for your reply. I swapped the unit out a while back and all is fine now :-) |
