NTB12-041
A new entry has been added to Knowledgebase, category 2011 Altima Coupe
Description: 2011–2012 NISSAN ALTIMA COUPE, ALTIMA SEDAN, ALTIMA HYBRID, MAXIMA, 370Z, MURANO, GT-R; IGNITION SWITCH (PUSH BUTTON) WILL NOT RESPOND 1.The vehicle you are working on falls within the Applied Range of this bulletin and 2. The following condition(s) exist or the customer reports the following condition(s) occurred: When trying to start the engine,
When trying to turn the engine OFF,
To check it out, rate it or add comments, visit NTB12-041 The comments you make there will appear in the posts below. |
Steering lock issue
Some people on the 370Z Forum are recommending that you can prevent the steering lock problem by pulling the steering lock fuse. Is this a viable solution to prevent the problem? Would there be any other issues that we should be concerned about if the fuse is removed?
