serpetine belt replacment
We need to replace the serpetine belt on our 2008 Rouge. Would someone give me a walk thru the procedure to accomplish this project?
1. Disconnect neg. batt. cable.
2. With 14mm socket and wrench, insert socket to auto tensioner pulley bolt and turn tensioner pulley CLOCKWISE ONLY. CAUTION: YOU MUST TURN ONLY CLOCKWISE. If you turn the tensioner counter-clockwise you must replace the entire auto tensioner. 3. When you turn the tensioner pulley, you will see the RETAINING BOSS hole line up. Then insert a short screw driver. You can role play the procedure. After inserting the screw driver, the belt is now ready for removal. 4. Rounting the replacement belt thru the A/C compressor and Crankshaft it is best to: (a) Jack up the passenger side and remove the passenger wheel. Follow procedure for proper support when working under the vehicle. (b) Remove the splash shield and the crankshaft should come to view. You are now ready to route the new belt thru the a/c compressor and crankshaft. Follow routing diagram. Be sure belt is installed properly. Rotate the tensioner CLOCKWISE again to release the tension and remove whatever you use from the retaining boss and let go. Reconnect the batt. cable and start car. If everything is good, re-install the wheel and tightened per torque specs. |
Drive Belt Diagram
Thank you so very much for your reply. This is a great help to us. :)
