Glow Plug Relay Circuit
Hey Guys,
Does anyone know where I can get an electrical diagram for the y60 patrol? Specifically the the starting system [glow plug relay control circuit(S)]. Any pointers would be highly appreciated. Sese |
Im certainly no expert but the experts will more than likely ask whether it's the
2.8 Turbo Diesel with after glow control or the 4.2. |
Ah, silly me. The engine in question is the TD42. Are the circuits on the two engines similar?
so far I've found they are quite different from each other, the 2.8 has two
busbars connected in parallel controlling the rear 3 glow plugs differently than the front 3 having a pre ignition glow then an after glow reduced to about 10v. The 4.2 has only one busbar connecting all 6 glow plugs in parallel without after glow. This is only what I've found so far, Im happy to stand corrected on any of this but the bottom line is I dont have a wiring diagram that will be of any use to you. cheers mate. |
Thanks pal, and you are correct about the busbar on the 4.2.
