2010 GT-R wiper blade refill replacement
Hello,
I need to replace the wiper blade refills on my 2010 GT-R. I can't figure out how to get the old ones out so I can install the replacements. Can anyone help with instructions? Thanks in advance |
1. Pull the wiper arm.
2. Push the release tab A , and then move the wiper blade down the wiper arm 1 while pushing the release tab to remove. 3. Insert the new wiper blade onto the wiper arm until a click sounds. 4. Rotate the wiper blade so the dimple is in the groove. http://x.nissanhelp.com/forums/attac...1&d=1317662091 |
Thanks for the info NissanTech, but I know how to remove the wiper assembly off the wiper arm. I'm looking for instructions on how to replace the blade refills within the assembly. I don't know how to remove the existing refills to replace them. Thanks.
my personal tip for winshield wiper is to take 400 to 600 grit sand paper and simply pass over the blade about 20 times from end to end..... this will allow you to use the same wiper for close to 2 years
