replacing timing belt on v60i 87 pathy
Hi yall ive been everywhere so i hope someone can help me. need to change the temp sensor on 87 pathy so since i need to remove everything to get at it figured i would change the timing belt while im at it. however i have a few issues.
1. how do i get the harmonic balancer off? 2. is it necessary to loosen all rocker shaft retaining bolts? 3. i need to get the back cover off to access the temp sensor because its in the way of placing a socket on the sensor is there anything i need to know before pulling the camshaft pulleys? or is there a special socket that will get around the back cover to the sensor? thanks in advance for any advice |
