02+ radio display fix
6 Attachment(s)
I couldn't find anything online on how to fix the dead display issue so I tore it apart and found the problem the old fashion way. Thought I'd post it here for everyone.
If your display is dead, blinking or alternating between dim and bright just re-solder these two surface mount resistors. These are surface mount resistors so just heat one side at a time, and hold it down while you heat it so it doesn't fall of the circuit board. |
Hi lanman,
Just wanted to say thanks so much for your post on fixing the '02 radio display, your steps and excellent pics all worked like a charm!!!! You rock!!!! I now have a working display on my '02 radio again!!!!!!! |
Amazing the resistor was loose, I poked gently at #732 with a screw driver and it moved on the circuit board, I used the solder method on both 732 and 733 as directed and it worked. FYI the radio needs antenna connected to complete ground circuit. mega thanks!
