2004 Maxima hard Hot Starts
About a week ago I got a p0340 & p1800 code, car had hard starting while HOT and for some reason the Car Horn stayed on after hitting keyfob to lock.
Cleared codes and got the 340 again. So I did my homework and read a lot of post from this site and became a member. I have recently replaced both Cam Sensors and the Crank sensor. Drove my car and I am still have hard Hot starts. Nissan said might need to reprogram ECU. Any thoughts? The forum has been a big help, Thanks!!! |
You might want to search for a ECU reset procedure for your model. There is supposed to be a process (key on, tap the accelerator, blah blah) that resets your ECU. Some of the more advanced ODB readers can do it, cheap ones won't.
I just ran into the exact same situation (P0340) on my 350Z. The weird thing is there is a recall for that on the Z, seems they consider it dangerous for Zs but not for Maximas?? :-P |
Thanks I will look into the Reset.
update
Googled ECU reset, got a lot of hits, read most of what I found and saw several steps in common. Followed the steps and cars started right up, better that it has since the codes, hope that was all it needed. Will keep up to date on progress. |
Update.
No luck on the ECU reset. drove car about 5 miles to store and it wouldn't restart, once I parked, it took about 20 minutes for it to cool before I got it to go. I need suggestions. Thanks. |
I don't know if this is your problem or not but my 95 Maxima had a similar hard start issue although it was when it was cold or would sit over night - driving it someplace after it started and then restarting it wasn't a problem.
It would turn over but wouldn't start. After replacing most everything fuel system related, I took it to my friend's shop and he diagnosed it as the ignition switch - I thought, no way. After replacing the ignition switch, she cranks like a new one. Not sure how to diagnose this issue as it didn't throw any codes. |
Try to change the engine thermostat it could sent wrong sigal to ecu.
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
