-   -   2000 nissan maxima water pump (https://x.nissanhelp.com/forums/maxima/1723-2000-nissan-maxima-water-pump.html)
enduro 01-21-2007 12:58 PM
Hi i am new to this forum. I am replacing a water pump on my friends 2000 Nissan Maxima with a dohc v6. I am having trouble getting the chain tensioner to move back enough to get the pin in it to hold it back. i am wedging a screw driver in the tensioner guide but i cannot get the water pump by the chain. PLease help!!!
vonsudderth 01-21-2007 09:13 PM
You have to take the other cover off and release the tension on the chain tensioner. Then you will have enough room for the water pump to come off.
bataradena 11-26-2009 06:19 AM
You need to loosen the chain tesioner bolts so the oil that's trapped inside can bleed out while pushing the tensioner piston in. I had the same problem and this is not mention in the manual.
Maxdom 11-26-2009 06:44 AM
That was almost 3 years ago. I hope that by now the original poster has figured that one out..... :)
:Welcome to the forum!!!...
bataradena 11-26-2009 06:49 AM
I know this but others who maybe searching this topic could benefit from this.
Best Regards
Byron
Maxdom 11-26-2009 07:14 AM
Best Regards
Byron
Got it. For a moment I thought that you didn't realize the date on this thread, as you were searching for answers to the problem you're having with the water pump you replaced.
