Best price on Nissan Maxima MAF 22680-2Y001
Who has the best price on an OEM Nissan Maxima MAF part number 22680-2Y001 to replace my faulty 2001 Pathfinder one?
Thanks, Autoeng |
Try courtesyparts.com or enissan parts.com
Picked one up at Pinnacle Nissan/Infiniti for $92.73. Seems to have solved the problem.
I paid 108.00 but well worth it compared to the 650.00 for OEM pathfinder. And yes, my pathfinder has never ran better. Had to clear the self learn data but after that, no problems or codes.
So this MAF will indeed work on an 02' pathfinder with the appropriate ECM codes (i.e. lean codes)?
Nothing extra need to be done to make this MAF work? Courtesy parts has this MAF for $109.54. If it works, I'll be happy to pay. Thanks, JJ |
Let us know how it goes... Been seeing alot of post about this swap in parts.
RE 2001 Pathfinder replacement MAS with a Maxima one
Hi there,
I've had the same problem with my 01 Pathfinder, I replaced my MAS with an aftermarket part (to try and save $400.00 bucks) but the truck wouldn't idle, the engine knock was gone, but every third light it stalled. The vendor told me my truck would adjust to the new MAS, but 2 days later it still stalled all the time?????? After this last episode, I've been a little hesitant to replace it again with something not made for my truck???? I was hoping you could clarify a few things for me? First, that the MAS from the Maxima does work? Second, that when you say “clear the self learn data on the car”, you mean clear the error codes with a code reader and disconnect the battery? Kyle |
I have a 2001 Pathfinder that had the MAF go bad and I took your advice and had the dealer put on the Maxima part - 108.00 for the part and so far it is working great. Thank you for posting this info and I have shared it with the dealer and their mechanic and parts department. It seems like everyone with a Nissan Pathfinder has had this part go bad. Saved me a lot of money and the light is finally OFF!!
