2005 Maxima Seat Memory does not work
The seat memory oprtion does not work. When you press the "set" button there is no activity (ie. leds flashing) from the memory buttons.
Does the seat works manually?
If it does, try resetting the system by disconnecting the car battery for about 5 minutes. Remember all your radio memory setting will be lost when you disconnect the battery. |
Yes everything works fine except for the memory option
Use your owners manual and reprogram the autopositioner. It could be possible for some reason the it has lost its memory. Keep me posted
Was finally able to remove the driver door panel and the wiring connector was detached.... Hooked it up and it all works...
