Disc read error
can anybody help me my pf 2006, 6 disc cd player has stoped working it just says DISC READ ERROR i have left the fuse out for 1-2 mins (what the main dealer said to do ) but no joy any ideas??????
Cheers Steve.... |
Try disconnecting the car battery for about 5-10 minutes to reset the system. If that doesn't work, the radio has to be removed for repair.
Are the discs stuck in the CD player? If so, it sounds like the same problem I had on my 6-disc changer in my '01 Pathfinder. Apparently, from everything I've read, this changer (Clarion?) is prone to getting jammed up due to poor design. I had mine do this, had the dealer send it back to get repaired as my car was brand new, but when i got it installed again the same thing [stuck disc] happened again only 2 days later. Fortunately the dealership had enough sense to flip the bill for buying me a new, single-disc player. Hopefully you'll have better luck with your player if this isn't the case.
Good luck. |
disc, error, read |
