#31
question
Hey bro! Whatever happend to your abs problem?
#32
Still doing it I should have read all the posts so now I have the left rear sensor and will pray that fixes it.
#33
AbS
Oh okay, I'm gonna change mine today. I hope that fixes the problem lol. But i'll update you on it.
#34
AbS
John did you replace the right sensor an the hub? Or you jus replaced the right sensor? Nissan told me to replace the hub and the sensor because the the hub was rusted out.
#35
Just the sensor, the hub had slight rust but that was easily removed with a dremmel and wire brush
#36
Abs
Ok! One more thing, What tools do I need replacing the hub an the sensor?
#37
Metric socket set to disassemble caliper ( make sure to support it somehow, bungee cord works well ), hub and baffle. All the bolts are on the back side of the knuckle. Jack stands of course. The most involved part is just disassembling the emergency brake before you remove the baffle.
#38
Also if you have a dremmel with a wire wheel that's handy to clean up any corrosion on the baffle and a grinding wheel to make the notch on the knuckle.
#39
Abs
Thanks john I appreciate that
#40
How do I get the sensor off? It sits alway under the car with two tabs. Think? And for the plastic hub does it pull out from the front or back?
#41
There's one bolt above the sensor on the back of the knuckle, then you need to follow the cable to its connector on the harness toward the middle of the trunk area. You will see where it plugs in, there will be a small rectangle on the connector just push in with a small screw driver in the middle of it and it will release the connector and it will slide out. It can be a pain the ass just because its hard to get to.
#42
John I'm talking about the two twist purple tie things. How do I get them out to take the sensor cable off
#43
I used a small pair of needlenose pliers to grab to pull/ twist off. The new ones you just need to push in until it clicks.
#44
Thanks for all your help, I replaced the hub an the sensor the slip,tcs,abs lights are still on. Man I give up I hate this car! My buddy told me I could clear it think I'm goin to trade it in. Don't know what else
#45
If you have a code reader see if its throwing any codes. If you dont you can bring it to any Advanced Auto theyll check it for free. Im going to do the drivers side rear this week Ill let you know if it worked. Until then I just disconnected the abs sensor on the front passenger side under the hood. Those lights stay on but the ABS will not engage, since its finally spring im not too worried about it.
abs, issue, maxima |
