97 Maxima Cold start up + belt problem
hey all, this is probably a simple question but i'm in depserate need of some help here. my car won't start when we have cold nights, it being new orleans here that isn't too often but if it's cold it won't start ( below 35/40-ish ) when the sun comes out full force later in the day it'll start ( rough + white smoke ). any ideas? not battery or alternator, had them checked.
second - had both belts replaced in what i'm asuming is a unrelated belt failure, the power steering belt has a lot of slack in it. did they mess something up? i'm thinking this should be pretty tight,. just like the drive belt. is there a way i can tighten this myself? would really appreciate some help with this one. thanks a bunch! vB |
Cold start problems are difficult to diagnose. There are some test you need to while the problem is occurring. The most common problem is fuel delivery, the engine is hard to start when there is not enough fuel pressure. When was the last time you service your maxima? You should start by replacing the fuel, air and oil filter.
my power steering pump on my infiniti i30/maxima will not drop i followed the diagrams and it still will not drop any ideas? in desperate need of help
belt, cold, maxima, problem, start |
